Run-Time Plot - Inretech White
Status
Not open for further replies.
Roy
Farewell our Curmudgeon Administrator
Granbury, Tx USA
This runtime plot is for a AA Minimag with a Inretech White LS modification. This mod is unregulated. At the end of seven hours and 45 minutes, it was still putting out enough light to see your feet with.
Equipment used is a photocell and a Radio Shack 22-805 multimeter with a PC interface that is using ScopeView software (V 1.08).
The vertical axis is in MA and the horizontal axis is 15 minutes per division.
Be aware that your actual battery mileage may vary from that indicated by this runtime plot.
Looks like a typical alkaline drain curve. After one hour, the current is reduced by nearly in half. I bet if you do the same to an CMG Reactor with alkalines, you'll get a similar curve.
Moved to reviews. Follow via the link up by your name.
Status
