kj
Links to runtime charts on my site:
Since my test environment is far from optimal, lux readings on my charts cannot be accurate. Actually, in my setup, the light sensor is close to the floor and I found the lux reading could be 10% lower if I cut the reflection from the floor. So please don't compare the lux reading with others (or at least take the above statement into consideration) because the test setup can be very different.
FYI, I once tried putting the flashlight itself on the floor and I saw the lux reading was 40% higher than my normal setup because of the reflection. You can see how the lux reading can vary depending on the setup from this.
- Arc LSL-S (1x123) PLOT
- Arc LSH-S (1x123) PLOT
- Arc LSHF-P (1x123) PLOT PLOT
- Arc4+ (#059, 1x123) Level 1~5 PLOT
- Arc4+ (#059, 1x123) Level 1 with various brands of batteries PLOT
- Arc4x (#0650, 1x123) Level 1 PLOT
- Arc4x (#0650, 1x123) Level 1 with SureFire, Duracell, Panasonic and Energizer PLOT
- CR2II (Madmax Lite, TV0J HD, 1xCR2) PLOT
- Firefly (Badboy 400, R4H HD, Fraen LP, 1x123) PLOT
- Firefly (Madmax Lite, R4H HD, Fraen LP, 1x123) PLOT
- Firefly (Madmax Plus, Q3 LD, NX-05, 1x123) PLOT
- Firefly (Madmax Plus, TW0K HD, Fraen LP, 1x123) PLOT
- Firefly with 2-Level Switch (Badboy 400 and Madmax Plus, 1x123) PLOT
- Ichishiki (Badboy 300, TV1L HD, NX-05, 1xCR2) PLOT
- Ichishiki (Madmax Plus, Q3J HD, Fraen LP, 1xCR2) PLOT
- Ichishiki (Super Converter, TWAK HD, Fraen LP, 1xCR2) PLOT
- LionHeart (Pila 150A) PLOT PLOT
- LongBow Micra (1x123) PLOT
- Longbow PR + McCapsule (Badboy 500, WX1S HD, 1x123) PLOT
- McLux PR-T (Madmax Plus, R4H HD, 1x123) PLOT
- McLux PR-T (Wizard 600, R4H HD, 1x123) PLOT PLOT
- McLux PR-T (Wizard 600, R4H HD, 2x123) PLOT
- McLux PR (DB500, TWAK HD, 2x123) PLOT
- McLux PR (DB1000, TWAK HD, 2x123) PLOT
- McLux PR (DB1500, TWAK HD, 2x123) PLOT PLOT PLOT PLOT
- McLux PR (DB1500, TWAK HD, 3x123) PLOT PLOT
- McLux PR (DB917, TV0K HD, 2x123) PLOT PLOT
- McLux PR (BB750, X3T HD, 2x123) PLOT PLOT
- McLux PR (BB777, W4T HD, 2x123) PLOT PLOT
- McLux PR + McE2S (BB750, X3T HD, 2x123) PLOT
- McLux PR + McE2S (DB1000, TWAK HD, 2x123) PLOT
- Mini Maglite (Badboy 400, R4H HD, NX-05, 2 x Alkaline AA) PLOT PLOT
- Mini Maglite (Badboy 400, R4H HD, NX-05, 2 x NiMH AA 2300mAh) PLOT PLOT
- Mini Maglite (Badboy 400, R4H HD, NX-05, 2 x Lithium AA) PLOT PLOT
- Mini Maglite (Badboy 400, R4H HD, NX-05, 2 x Oxyride AA) PLOT PLOT
- Mini Maglite (Badboy 917, TW0K HD, NX-05, 2 x Alkaline AA) PLOT PLOT
- Mini Maglite (Badboy 917, TW0K HD, NX-05, 2 x NiMH AA 2300mAh) PLOT PLOT
- Mini Maglite (Badboy 917, TW0K HD, NX-05, 2 x Lithium AA) PLOT PLOT
- Mini Maglite (Madmax Lite, R4H HD, NX-05, 1 x Alkaline AA) PLOT
- Mini Maglite (Madmax Lite, R4H HD, NX-05, 1 x NiMH AA 2300mAh) PLOT
- Mini Maglite (Madmax Lite, R4H HD, NX-05, 1 x Lithium AA) PLOT
- Mini Maglite (Madmax Lite, R4H HD, NX-05, 2 x Alkaline AA) PLOT PLOT
- Mini Maglite (Madmax Lite, R4H HD, NX-05, 2 x NiMH AA 2300mAh) PLOT PLOT
- Mini Maglite (Madmax Lite, R4H HD, NX-05, 2 x Lithium AA) PLOT PLOT
- Mini Maglite (Madmax Lite, R4H HD, NX-05, 2 x Oxyride AA) PLOT PLOT
- Mini Maglite (Madmax Plus, Q3 LD, NX-05, 2 x Alkaline AA) PLOT
- Mini Maglite (Madmax Plus, TW0K HD, NX-05, 1 x Alkaline AA) PLOT
- Mini Maglite (Madmax Plus, TW0K HD, NX-05, 1 x NiMH AA 2300mAh) PLOT
- Mini Maglite (Madmax Plus, TW0K HD, NX-05, 1 x Lithium AA) PLOT
- Mini Maglite (Madmax Plus, TW0K HD, NX-05, 2 x Alkaline AA) PLOT PLOT
- Mini Maglite (Madmax Plus, TW0K HD, NX-05, 2 x NiMH AA 2300mAh) PLOT PLOT
- Mini Maglite (Madmax Plus, TW0K HD, NX-05, 2 x Lithium AA) PLOT PLOT
- Mini Maglite (Madmax Plus, TW0K HD, NX-05, 2 x Oxyride AA) PLOT PLOT
- NLS (Micro Converter, 1 x N) PLOT
- Pelican M6/McModule (0.5 ohm, TV1L HD, 2x123) PLOT
- Pelican M6/McModule (DB700, TV1K HD, 2x123) PLOT PLOT
- Pelican M6/McModule (BB700, V4U HD, 2x123) PLOT PLOT
- ROF-1 (1x123) High PLOT
- Super Flashlight 1 PLOT
- Super Flashlight 2 PLOT
- SureFire The Beast (20x123) PLOT
- SureFire L2 (2x123) PLOT PLOT
- SureFire L4 (2x123) PLOT PLOT (Note: My L4 seems much brighter than average L4s.)
- SureFire L4 + McE2S (2x123) PLOT
- SureFire L5 (2x123) PLOT
- SureFire KL5 (3x123) PLOT
- SureFire L6 (3x123) PLOT
- SureFire KL6 (6x123) PLOT
- SureFire U2 PLOT(Lv1) PLOT(Lv2) PLOT(Lv3) PLOT(Lv4) PLOT(Lv5) PLOT(Lv6)
- Var-I-Pin (1x123) PLOT
