Run time test for STRION?
Hi fivemega, thanks a lot for that runtime test! /ubbthreads/images/graemlins/thumbsup.gif
How long did it run on full brightness and when did it start to dim? Or did it die immediately?
If it has a good throw also I`ll get me one. BTW where ist the best place to buy them at a good price?
Thanks for response, /ubbthreads/images/graemlins/bowdown.gif /ubbthreads/images/graemlins/grin.gif
Wolfgang
5M,
Thanks for the test. Did you have a chance to observe or measure brightness maintenance?
Brightnorm
Wolfgang, it has pretty good throw, and an adjustable focus. I got mine from TTS, for about $80. They had a few left the last time I checked. More info on the TTS special here. And here is a post with pictures and more info about the light itself.
-Mike
Fully charged up battery reads about 4.026 volts
Soon as turned on, reads about 3.495 volts
Voltage slowly dropped down to about 2.930 at end of 70 minutes and then cuts off. This voltage stays about same as long as switch is "ON"
Soon as you turn switch "OFF" you will read about 3.130 volt and may come on for few seconds if you switch it "ON" again.
I don't have a light meter but brightness is very steady for first 50 minutes even dough volt meter shows some drops, then it gets slightly dimmer but still bright enough. After 60 minutes you will notice dimmer and some yellowish beam which is still brighter than many regular alkaline flashlights.
I would say brightness and throw is similar to new Stinger but beam is whiter and of course smaller and lighter. Overall, it is great flashlight and worth for it's price.
Prices may wary from $80 to $110 depending where to get it and what option (one or two charger, one or two bracket, AC or DC cord or both)
Good luck and please let us know your opinion after get one.
Brightguy has them with AC/DC and one charging cradle for $79 plus the best service I have ever seen. /ubbthreads/images/graemlins/smile.gif
Thanks a lot guys, /ubbthreads/images/graemlins/thumbsup.gif
just have to buy one!
Greets from Germany,
Wolfgang /ubbthreads/images/graemlins/smile.gif
