Runtime: RCR123A vs CR123A
ImGeo
How is the runtime of rechargable 123's compared to non-rechargable 123's.
I've been looking on dealextreme, and based on what I've read, it seems the 350mah LiFepo4 have actual runtime of 400mah, as comapred to the other ones that claim from 650 to 1000mah underperforming the 400mah lifepo4.
Basically, I believe the best rcr123 at a fair price is only going to have 400mah. How does that compare to a regular CR123a?
I'm looking to use this in a Inova X0. If I get RCR123, I will get the 3.0v type with the proper charger.
Hello ImGeo,
Welcome to CPF.
You may find this thread useful.
As you can see, the capacity of a cell is related to the rate you discharge it at, but in general, primary CR123 cells are usually rated in the 1400 - 1500 mAh range.
Tom
