OK, it's been so long since I've done it any other way, that I don't actually remember precisely what happens. Mind you, that using a bench PS has never been my primary means of charging any kind of cells, with the exception of NiCd/NiMH battery packs, at a 0.1C rate. Also, I used the PS to charge LiFePO4 cells in parallel for a couple months, as I didn't have a proper LiFe charger for cells larger than 16340's. Presently, I only use the PS for parallel charging NiZn cells. For Li-Ion cells and NiCd/NiMH packs, I use a hobby charger.
That said, from what I can remember, with my PS you cannot preset or adjust the voltage or current with an open circuit. With a cell in the circuit, the voltage can be limited (but of course cannot be set below the present circuit voltage), and current can be adjusted from 0-2A.
With the cell in place, you cannot push current through the cell until the voltage knob is turned up to some point higher than the circuit voltage. This is a "blind" operation, as the voltage reading will still read the circuit voltage. As the voltage knob is turned up, at some point, you will be able to start pushing current through the cell. If you turn the voltage up just enough to allow, say 500mA current flow, as the cell's voltage increases, the current will decrease, and you're basically running CV. Therefore, with this type setup, it's a whole lot easier to just turn the voltage knob up all the way, rather than trying to guess where the "sweet spot" is that would allow 500mA of current to flow until the 4.20 Volt point is reached.
Again, a programmable PS would make this part a whole lot easier to accomplish. And, for me anyway, a hobby charger actually works out better.
My apologies to SilverFox, for taking this thread way off topic.:candle:
Dave
