red02
- Joined
- Apr 11, 2010
- Messages
- 975
Re: Why are warm LEDs preferred by most on this forum?
the snow density is continuously changing. The amount of particles in the path of the light is not constant even if you take it second by second and only consider one light. Since the CW light has to travel longer to get to the ground, naturally there would be more snow in it's path. If you look at the hotspots they are nearly the same. Not to mention the efficiency difference between 5A and WC that obscure any results. my point is that there are no meaningful conclusions as the testing method is not scientifically sound.
this sounds like a circular argument, your simply restating your premise as a conclusion.surprise surprise, the warm penetrates better while the cool is confounded by all the crap in the air between the user and target :whistle:
and thankfully he switches back and forth between both lights a number of times, all with the same result!!
