Has anyone disassembled a Scorpion's head assembly?
I bit the bullet and removed the lens from mine and was thinking the rest of the assembly would come out... Nope.
It doesn't seem like it comes out the back, nor the front. Perhaps it is a one-way install?
On another note, there is a channel for the lens (something else I couldn't tell until I took it out) so my glass replacement lens will have to be slightly smaller (1mm?). There is also an "O" ring that the lens fits up against.
So how do you think I should secure the glass lens? Silicone?
On yet another front, I was thinking about trying to waterproof a Scorpion. I was thinking about cutting some of the rubber back a bit and put an "O" ring or two on the body and put a ring of silicone under the rubber so no water gets down in there? Thoughts? Any idea what size "O" rings to use?
Thanks,
-john
Thanks,
-john
