Re: Sealed Lead Acid, What\'s the story?
Thanks, folks for the nice comments! I spend a lot of time working with batteries and love to share and learn. There're some really great and knowledgable (and talented!) folks on these boards, and I'm happy to be able to contribute and absorb knowledge. There's always more to learn.
Cheesehead:
The voltages are pretty much the same accross the lead/acid types. The per cell voltage is what's critical, and does vary by temperature. (Warmer battery, use a lower voltage float charge.)
The good thing about it is that you don't have to be real precise. I always try to aim a bit low, just in case, as I'd rather not get the total capacity of the battery, then lose it totally or really wack the capacity by drying it out..
It's very true that moderate overcharging on a 'flooded' or wet cell is far less of an issue, 'cause you can refill it. As long as the plates don't warp or dry out, it'll usually be fine. Overcharging a gel or starved cell, tho, can dry it out, along with venting corrosive gasses in your equipment. And they may swell and crack.
Fortunately, for most electronic equipment and temperatures, a rather simple regulator circuit can handle it well.Some of my home-built emergency CCFT lanterns have been on-charge for 4 years+, most with used batteries, and the only one to fail was after 5 years running on a originally 7 year old battery. With a stated 6-10 year life. The charge controller's extra parts from a standard 'Wall-wart' or cheap car charger add up to about 80 cents, and are only, with charge limiter, about 5 parts.
As for using a wet cell, they're nasty. Not only would it ruin your clothes and make you itch like crazy, it can ruin your light, too.. /ubbthreads/images/graemlins/grin.gif Or tip over in the trunk and eat thru the car..
(I semi-collect early transistor or hybrid radios, and some battery tube sets. GE made a series of 'portable' radios in the 40's and 50's with a single 2V Willard wet cell, designed to be plugged in at night and charged, then taken to a job site and played for 8hours daily. Built like a tank. The battry is clear, with three little balls to indicate charge level, a fill plug, and a vent hose. Not real spillable, but very wet. I'm restoring a couple of these using modern conversion technology, but still a sealed 2V battery.. What can I say? I'm wierd..)
I'd rather just regulate the charger and use my SLAs.. Some of the best-lived ones I've encountered for general use, with rather good standby retention as well as good float life, are the Panasonic units. I've also had good luck with the round 'D' sized and up Gates-GE types, tho they do tend to end-of-life suddenly. Tho, if treated right, that's been 10yrs+. 2 Gates 2.5AH 'D' size in a 3D m*g with a halogen bulb and the charge reg built into the tailpiece, hold up for over a year uncharged, and still lasted years on used cells.
Anyway, I'm getting glared at. Time to go to bed..
Hope this info has been useful..
Keep on glowing!!
Yours, drs the crazed..
