Sold/Expired Sell:custom Quad XP-G P60 module 1st Run *open*
kerberos0023
Tokyo Japan
:welcome: I sell this!
The 1st run will be limited to 10 Direct Drive XP-G R5 only!
I begin to sell it for $160 including the EMS postage!
This becomes very hot.
The use battery is with 3.7V Li-Io battery protection circuit.
If a light becomes hot, please cut the light which is in a dangerous state.
Please be careful to the handling.
After understanding, please refer as things mentioned above.
?This light creates excessive heat :caution:
?This light may cause eye damage :caution:
?This light will burn the skin at close range. :caution:
?This light may cause combustibles to ignite :caution:
?This drop-in is a direct drive unit. :caution:
?IMR cells are not recommended. :caution:
:thumbsup:
I sell this custom Quad XP-G P60 module.
This light creates excessive heat.
Please use 18650 or 17670 expensive battery of the electric discharge performance.
The payment is PeyPal.
Post your order here and I will PM you the total along with my PayPal address.
A photograph is a trial product. I update it later. I perform the shipment sequentially from the end of November.
Cutter-XPG25RDR5-CW (remodeling board 20mm)
Carclo 24mm Quad Optics
This is a trial product
