taewoopa
PM sent about an special order just like same as Octaf.
Please check.
Please check.
Hi taewoopa,PM sent about an special order just like same as Octaf.
Please check.
Hi keller,Hi,
I would like to bay the same heatsink, is there such a possibility?
Hi keller,
Do you want only a heatsink?
Thanks,
Kenji
I sent PM.yes only a heatsink.
Thanks,
keller
Hi candle lamp,Hi kerberos0023,
I sent PM. Thanks.
When I send PM to you, there is message as follows :Hi candle lamp,
I do not receive PM. :thinking:
Kenji.
Hi LocoDuck,Trying to get ahold of an R4 unit for a 6P, hopefully I have found my way to the right thread. Can you shoot me a pm or email?
Hi Bob96,Received my R-4 unit. Very nice. Delivery to USA was an impressive 4 days. Compared to my regulated - single level - neutral - Modoo and were very close in brightness & beam shape. Your module uses a 18650 and mmy Moodoo 2 X 16340 cells. Run time on yours should be double. I think that the R5 is a little brighter than the R4 but the R4 does have a nice natural tint to it.
How about a Direct Drive R5 using one 18650 cell. Could be one level or three. Like the limited edition that Moodoo made = 1600-1700 lumens. Would need a longer center spring to use the Zero Resistance Switch as this switch depends on the module spring as it has no spring. Your current + springs are very short and I doubt they would work with this switch? would love to have one of these direct units. Run time would be short and lots of heat too.
Hi Bob96,Hello,
Sending Paypal for:
R5 - Module Kit - Matt Black - Single Level is Fine - Direct Drive for a single IMR18650 cell. Bright One!
Thanks,
Bob96
