I am wanting to build a 4 HBLED light. Been playing around at the bench. If I wire the 4 LEDs in series, then I can run them off a 14.8V battery. If I run 2 LEDs in series and then 1 in parallel off of each of the "in series" LEDs, then I can run it off a 7.4V battery.
I have used the LED PRO calculator for estimating run time on the "in series" configuration, but I am unsure what to do to estimate run time on the "series/parallel" configuration. I am wanting to use a constant current driver set up for 700ma.
Can someone please help explain the difference in run time of an "in series" configuration versus a "series/parallel" configuration, if any?
