I've tried searching but to no avail, can someone please tell me the easiest/ safest way to take the bezel ring off a SF C head to replace the lens with an UCL?
I used to use a heatgun, but a torch is faster......just BE CAREFUL not to get it TOO HOT....
Start out with a little....You can always add more heat if needed.
I have used needle nose pliers in the detents on the 6P bezels and it has been working to open 6P, M3, & KL2 heads. Ijust opened them until the needle nose ends fit into the detents, then turn...
