I don't yet have the sharpmaker by spyderco, because I just orderred it and it's on the way to me right now along with the diamond sticks and ultra fine rod options. However, I trust the other peoples' opinions here and I believe it will prove to be my most valued, economical, sharpenner. Based on this, I would make the following recommendations to anyone interested in a sharpenning system:
Get a sharpmaker 204 by spyderco. Get the coarse diamond rods. Get an ultra fine ceramic rod for it.
If you want to know what's going on then buy the vhs tape by razor edge. Also, go here and read the free info on sharpenning; if you like it enough you can buy his book.
http://www.sharpeningmadeeasy.com/
I also am waiting for my new fast sharpenner. The redi edge pro which is a carbide slot on a ceramic hone rod.
http://www.klawhorn.com/rediedgepro.htm
I had a myerco sharpen it that an author recommended but for the life of me I can't get it to work well. I get much better and faster results with my cheap plastic carbide sharpenner. THerefore I'd recommend the expensive durable redi edge pro which should be even better than my cheap plastic thing. If, when it arrives in a day or so, I find it doesn't live up to its hype then I'll repost here. If I don't then it was all it was cracked up to be. I find the slotted carbide sharpenner, cheap plastic one I have, really can put an edge on fast. It can even sharpen dull edges like the FALSE double edge on knives made to look like a dagger but one side is really just decorative. With this carbide sharpenner, as long as the edge is reasonably narrow to begin with, it's no problem. I've sharpenned 2 of my kabar knives which came with false back edges. Now all the edges are razor sharp. The carbide sharpenner cuts a lot faster than the spyderco. It can get to shapes that are hard to sharpen on the spyderco. But, for knives suited to the spyderco, I prefer the spyderco for a quality edge. I find that together, these two systems work very well and FAST.
Unless you bought a bussecombat knife with the assymetrical edge in which case you need a strop and paste. However, I reviewed the company's posts and the owner of bussecombat said that they warehouse their knives as blanks that are sharpenned upon an order being placed. Therefore, he said that it costs his company nothing to change the edge type to suit individual preferences. So, if you want a bussecombat knife with a standard wedge or hollow grind, you just have to mention that with your order and then you won't even need to buy a leather strop. Although, the edge won't be as strong as the assymetrical edge, but it still will be stronger than anything else other than cpm3v blades.
