"shelf life" of cr123a flashlight?
srmd22
Boston, MA
I noticed this statement on the spec's for a nitecore EX:
"When the light is off, the microprocessor draws very, very little power - between 0.1-0.4ma (0.2ma typical). For example, one 2000mah cell would last about 416 days!"
...so if you throw it in a drawer, or your car, and don't use it, it'll be dead in around 13 months. I kinda figured these lights might last a few years unused, like some of my older led lights (even on alkalines). I figure same for A and AA lithiums.
Is this a typical set up, or do some other brands have a longer shelf life? Does it depend on the switching mechanism/microprocessor?
It depends on the user interface, i.e. switching mechanism/microprocessor and on the EX10/D10 you can just loosen the tail to prevent the drain.
I have collected a (partial) list of light with drain here: http://www.lygte-info.dk/info/standbyCurrent UK.htmlhttp://www.lygte-info.dk/info/standbyCurrent UK.html
That is because the Nitecore EX doesn't use a mechanical switch, which physically cuts off the current. The same principle of a TV in standby mode.
In theory a flashlight should have 10 years shell life until the battery dies, that if none of its components get rusty or fall apart
Perhaps, but if you're only using it once every 13 months, it's a bit academic isn't it ?
As HK says, a quarter turn of the head will prevent the drain anyway.
Sensible to lockout any light if you're going to leave it just for a day, let alone months.
Ok, the lockout tip is a good point - I had wondered about that. Wasn't sure if lockout actually disconnected the circuit, or just prevented the switching mechanism.
Thanks for clearing that up!
