Some people complain that lights like the Arc AAA are too long (around 67mm including the lanyard lug) for a keychain, which is reasonable. The Peak LED "pocket" design eliminates the lanyard lug to make the light shorter--but then there's no way to put it on a keychain or lanyard. Here's a proposed flat rectangular alternative setup, which I think could be as short as 48mm or so (an AAA cell is 44mm long and 10mm wide) and maybe 18mm wide and 13mm thick. The diagram is very crude but obviously on the right side either the lower right corner could be cut off (with the lanyard hole moved further up) or else the LED and circuit board could be moved downward with the led aiming out over the battery. I imagine this being made of plastic and snapped together or held together with a small screw or two. Obviously there would be wiring between the battery and the circuit board, not drawn here. Thoughts?
