Hello CPF'ers. I am looking for an incandescent that is very bright, small, and rechargable. It appears that the SL strion may be the answer. Is there anything (mod or stock) out there that rivals the strion with that criteria?
redledz said:Hello CPF'ers. I am looking for an incandescent that is very bright, small, and rechargable. It appears that the SL strion may be the answer. Is there anything (mod or stock) out there that rivals the strion with that criteria?
cratz2 said:You should be able to run 2x17500 cells on a bulb intended for 3x123 cells. Protecteds would be best, but I have no idea if they will fit into the Surefire tube.
The cool thing about the Strion is it has very impressive throw for such a small light. Probably twice as much throw as a P61 lamp.
About the only incand light I still run is the Streamlight TL-3 on 2 x17500 cells. I've bought and sold 2 Strions. First one I just didn't grow to love the beam. The second one was after I already had my TL-3 but before I switched to rechargeable cells in the TL-3.
For me, the TL-3 is about perfect.
Having said that, if possible tint issues aren't a major stumbling block, the Luma M1 Hunter has almost as much throw as the Strion or the TL-3, but the stability of LED, 4 times the runtime when using a rechargeable 18650 cell and the ability to click over to high and get 20+ hours of runtime.
Outdoors Fanatic said:Why not a SureFire E2E with the Lumens Factory EO-E2 bulb? It can't get smaller than that... It won't be as bright as a 9P with the P91, however this flashlight is a giant next to the E series and the discharge curve will be flatter on the E2 with the E0-E2 on 2xRCR123.
I didn't suggest him to use the stock E series lamp. I said Lumens Factory bulb for the E series, which is a MUCH brighter high-quality aftermarket bulb designed to run on rechargeables. The LF EO-E2 bulb SMOKES the strion bulb by a good margin, there is no contest here.GadgetTravel said:Hmm, interesting thought. He said real bright so I didnt think of the E series. Even the high power lamp in the E series pales next to a TL3 or a Strion.
Outdoors Fanatic said:I didn't suggest him to use the stock E series lamp. I said Lumens Factory bulb for the E series, which is a MUCH brighter high-quality aftermarket bulb designed to run on rechargeables. The LF EO-E2 bulb SMOKES the strion bulb by a good margin, there is no contest here.
redledz said:Thanks for all the information here guys. That E2E with lumens factory bulb is very interesting. Is that E0-E2 bulb under the D26 4 series? I think I'm going to research the Wolf Eyes lights some more also. After Tuna suggested them, I went back to FLR and thought, dang I completely overlooked these lights and PTS has several more that are affordable and compact.
Outdoors Fanatic said:No. The EO-E2R (AKA Extreme High-Output bulb for the E2 series-- R stands for "rechargeable"), is a completely different product which is under the "E Series" category at the Lumens Factory website:
www.lumensfactory.com
Cheers.
