My AA and AAA Lithium Primary cells (Energisers) have a date on them (March 2023) so I can leave them in their torches for another thirteen years and they should be OK ... I would suggest that you try them rather than the Alkalines ... I doubt very much that you would be able to leave your alkalines for thirteen years and still have a useable torch.Every time I need to use my flashlight, the batteries are dead from being corroded. Should we just not put batteries in flashlights till we need to use it?
Lithium batteries do not leak like alkalines do.Up to this point, I've only used alkalines and usually just leave them out until I need them. No use letting them discharge for nothing. I haven't ever run into a situation where I needed light "immediately".
With my likely upgrades coming to flashlights that use 18650, I need to check out that issue with those, too
On that note, for instance, how long can you keep 18650s reliably in a flashlight without recharging them or using them? A month? 3 months? A year?
I have bought some old stuff with leaky nicads in it.
Wow, they must have been really old cells. Modern NiCd and NiMH cells are built with an electrolyte-starved design. If you ever happen to open one you will find that it is barely damp inside, with no visible liquid. This is why you hardly ever hear of a NiCd or NiMH cell leaking. They may vent and release gas, but rarely if ever do they leak liquid electrolyte.
NiZn cells are a different story. These appear to have a flooded design and leak like sieves when mistreated.
Cheers,
BG
I had some very old NiCads (maybe from the 80's) that had some kind of "leak". Near the cathode they developed some kind of whit crystals, but not the kind of leak you can get with alkalines (like a corpse bleeded to death).
Buy good quality batteries and it will be fine to keep the battery in your flashlight
I wouldn't keep alkalines in anything unless I was sure to check it often for leaks. I have had way too many things ruined by them.Buy good quality batteries and it will be fine to keep the battery in your flashlight
