Show your charging setup
zx7dave
Seattle
So I am looking to improve on what I have by getting ideas on how fellow CPFers setup their batteri charging area...mine is still pretty modest for now...
Man, you guys are nuts with your rechargeable battery:p I have never seen a community of people so into battery and battery technology:laughing:
I'm looking for some kind of fireproof mat or fabric to lay my charger on, any recommendations?
I am just using a towel...thanks for my first upgrade..a fireproof cloth...good idea...as far as where to get one I would have to fall back on the handy google search. Good thought. I do have a fire extingusher handy, but had never thougth about the cloth...
Find a cheap welding blanket. Or a piece of metal. Or both.
Your charging station is much more organized than mine! Tool chargers are in the garage, other chargers are in my office, except my bc-700 which currently resides in the closet on my dresser for those middle of the night discharge tests!
Wow..that is very cheap....and I live very close to a Harbor Freight store that I have never been in...gives me a good excuse..thanks.
From Harbor Freight's web site:
General purpose welding blanket provides thermal protection from sparks and spatter.
  • Made of flame retardant flax canvas
  • Working temperature: 1000° Fahrenheit, 800° Celsius
  • Brass grommets on each side, approximately every 12''
All blankets are subject to burn through from molten slag/metal. Direct contact with extreme temperature and flame may result in smoking or fire. This product is intended to provide partial protection during light duty welding and grinding jobs.[FONT=arial, sans-serif]Dimensions: 6 ft. x 6 ft.[/FONT]
[FONT=arial, sans-serif]<<<<<<<<<<<[/FONT]
[FONT=arial, sans-serif]Although the blanket is a major improvement over normal surfaces, it may not provide complete protection. From a quick read of the following Li-Ion combustion temps are in the 1,000-1,200F range and actively combust for 20 to 30 seconds. A sheet metal cover may be a better choice.[/FONT]
Sorry I can't quickly locate the full original online text document, but here's an abbreviated version. [FONT=arial, sans-serif]http://ntsb.gov/events/2006/PhiladelphiaPA/Exhibits/350562.pdf[/FONT]
The source document is titled DOT/FAA/FAR/AR-068/38 September 2006
Flammability Assesment of Bulk Packed, Bulk Packed, Rechargeable, Lithium Ion Batteries In Transport Category Aircraft.
Granted a battery issue should be a rare event for the CPF educated.
Cheers
Yah, I did consider that some time ago. But after looking at the pictures of the lipo sack I realized even it could burn through. I don't plan on buying asbestos so fiberglass or canvas welding blanket should provide an adequate protection. If placed over charging batteries with an air gap I expect it would do a lot to contain sparks and flying debris. If you put the blanket in a fire, even a wood fire, it would be done for, but for a brief contact with a burning battery, well, it would help give me piece of mind.
I may have to build a little frame house for my charger with this, right now I just throw a scrap over the top.
Ok cool I sort of feel better now. For a moment there I thought that I was loosing in it after seeing all of the chargers that I have laying around.
I use ceramic floor tiles. I have a box left over from when I did my kitchen. You can buy them individually tho and select a nice looking pattern to boot! Mine are 13" square. That looks about right for your table. No need for mortar or grout, but that would be nice! :tinfoil:
Funny you should mention this. I went to a place where a bunch of businesses drop off things they don't use. Lots of teachers go to find things for their classrooms. I ended up grabbing some ceramic floor tiles which I intended to use for my laptop.
I was charging up some cells the other day and it dawned on me that one of those ceramic tiles would be a perfect charging platform. Working great so far . . .
Like others have said, that's far from modest! :kewlpics: Mine's not even worth posting a pic of. I've got a Pila IBC and a Nano. I don't own anything bigger than a 18650 so Pila suits me fine.
Here is my charging setup. RC lipo charger and 12v power supply. I charge my sanyo 2400mah and 2600mah cells at 1amp. I figured why buy a cheapo charger (ultrafire) when I can just use my RC charger that I already own. It's not as neat looking as a Pila but it works.:D That power supply was salvaged from an old netopia router and 12 18650 cells from two relatively new laptop battery packs. Recycled tech is cool.:rock:
Here is my discharge setup. When ever I need to test a cell I can safely discharge it at about 1.1amps using a automotive brake light with both filaments soldered together for max current draw. I am also using a lipo cut-off circuit from battery junction. It cuts off at about 2.8-2.7volts. I have done a dozen discharges on this setup and it has always cut off perfectly.
I am new to flashaholism but I have always been dabbling in electronics/engineering so this is just another way for me to have fun with electricity. CPF and all the brainiacs in this forum rock!:thumbsup:
ajaygr
