Superorb
L2P - stock with low voltage 3-mode and lanyard ring with 18650
What drop-in is this?
black_rose and winx thanks!
winx...eyeballing it, i think that if I remove the origianl L2P switch the KD forward clickie can be soldered right in, can't it?
Ahh, I've got that same drop-in. It's not bad, but I wish the medium and low were both lower. It's a great value for the dollar though.The Solarforce one, 0.8-4.2v 3-mode, yellowy/gold coloured label.
Unfortunately, the DX one doesn't allow you to save the user-selected modes.DX sells a variable [ ramping ] drop in that is very nice ..
!8650 to 2xCR123A [ 8.4v ] and works a treat .. In moon mode it will run for a very long time .
Yes, but there's only 1 level; I'm looking for a 3-level where I can choose levels quickly without ramping every time.What ever light level is chosen , is remembered .
Just got my L2m (Gunmetal) with Stainless flat bezel and clip.
Personally Ive found the 3 mode Lo voltage Solarforce drop in to be rather well set out with the modes / 1.2A / 0.45A / 0.09A
0.13 / 0.6 / 1.4A [ 2nd one ]
that is with Lithium rechargables or Alkalines Nimh? seems low for the latter
I tested my 0.9-4.2v SF dropin yesterday and got similar same draw as your 1st one with a fresh off the charger 18650. 1.21A, 0.48, 0.10Well , you wanted lower output , otherwise you get what you get , there is no guarantee as to actual current draw etc , unless you buy a pre tested drop in .
Ive found current draw to be all over the place with most drop ins , so it's a bit of pot luck , unless you can find a seller who will pre test for you .
Nice! Where did you get this?
