xdayv
Appreciate the clip options being offered, Thetasigma!
No problem, being able to buy these options at a larger quantity I have been able to get a little better pricing, so both options are $25 installed with screws instead of the $30 of the Okluma clips previously.
And they fit much better on your bodies!
I apologize in advance if this was already asked, but can you get these in host form only? No LEDs, drivers, batteries etc?
thanks!
SG3
edit:
nevermind, I see the pricing in the specs document.
@Thetasigma - is the Mcbrat clip compatible on the Regulus 18350?
Are there any white wall shots of the Regulus available?Depending on your eyesight, 150-175 yard practical range on high. I can see around 175 yards with it personally. I can only see about 60 yards tops with a triple running good and hot.
Thanks for the kind words above Ozy!
I don't think that you'll be able to easily lego the heads even if they fit on the other hosts, the pill design is different and a Regulus head on a 18650 body would be too short for 18650s and too long for 18500s.
Lego-ability was considered when designing the Regulus, but I opted for doing the best setup for my design goal rather than compromising the end result for lego-ability. Since battery packs are matched to their respective heads, they wouldn't always necessarily fit on a different head.
Looks like there is 1 spot left on the Regulus reservations.
Arch, what a great review. Not too long but very informative with real world comparisons. I have a couple of the BOSS lights and several Sigma lights. Am looking forward to getting a Regulus as well. Sigma lights are not only great to look at, but also well built and built to last!
As for "whitewall" effects, there are indeed some artifacts seen with the N319A having uneven tint through the hotspot. Initially I had considered using a light diffusion film or frosted optic to smooth this out, but in real world practical use, trading that for a reduction in its true strength (excellent throw) seems counterproductive. I have different flashlights which are much better for near distance tasks, requiring optimal color rendering and perfectly even illumination.
Did yours come with an optic installed? or just the default, correct me if I'm wrong -- medium spot?
Regulus comes with the optic installed.
