Szemhazai
Some days ago I get in my hands two headlamps : Silva Alpha 6 (about 349 € / 500 $ ) and Petzl Ultra Blet 4 (about 299 € / 499$) :santa:
Here you can see what came out from that meeting
Heads are similar in size, but it is easy to see that ultra is beating the alpha in led's quantity .
3x Luxeon K2 TFFC vs 6x Seoul Semiconductors SSC P4
But the claimed output doesn't show that:
540 lumens vs 350 lumens
Alloy vs. composite, what will be lighter ? Alphas head weight only 183 g instead 213 g of ultra
Power source – both are using 7,2V Li-Ion packs but they have totally opposite approach to that case.
Silva is using heat shrinking tube and neoprene - battery pack weights 326g and have 6,9 Ah capacity.
Petzl instead is using hard composite case - battery pack weights 270g and have only 4.0 Ah capacity.
Additional equipment.
No extras from petzl, but Alpha is very universal headlamp, in addition to head strap you are getting a clip on helmet mount and a handlebar mount. You can easily convert yours alpha into a bike or a helmet light.
Light output
I was wondering why Petzl is getting only 350 lumens from the Ultra for some time, only 350 lumens from 6 emitters :huh2: After seeing it for the first time in catalogue I was betting that this lamp is overheating and I was right.
On the left, Ultra on high right after turning on, it is giving about 450 lumens - compared it to my quad Cree - then about 10 minutes later… Everything is clear :thumbsdow.
Power consumption and burn time:
Alpha 6
Petzl Ultra Belt 4
So, claimed runtimes are ok, then... :naughty:
Let's take it outdoor, there was about 2 Celsius degree outside so both headlamps were pretty well cooled .
On high :twothumbs
On mid
On low
And alpha's flood (only led is burning) vs ultra low.
Reflective markers are set in a 5 m distance - the light is pointed on 10 m marker.
Light output
Alpha 6
Code:
mode V-in I-In P-In Calculated burn time.
high 6,8 2,060 14,01 3,64
mid 7,1 1,506 10,69 4,77
low 7,1 0,093 0,66 77,32
flood 7,1 0,572 4,06 12,57
Code:
high 7,3 1,250 9,175 3,13
mid 7,6 0,432 3,292 8,74
low 7,7 0,117 0,903 31,88
On high :twothumbs
On mid
On low
