Kestrel
I want to hotwire a pair of simple 4xAA bicycle headlights (2.5 watt Specialized PreView 2.5’s). (I posted this in /Incan and not /Bicycle since this is a simple bulb replacement question w/ a standardized bulb base). I just want to upgrade the lights with a simple drop-in replacement bulb, something inexpensive and hopefully local (i.e. no shipping) – a maglite bulb or even a generic department store bulb would be fine, for example. Each light will be using 4 NiMH in series. Runtime is not that important, but the issue is the plastic reflector and bulb mount, I figure that anything that will not melt the plastic will provide sufficient runtime for my purposes, ~45 minutes max. There are a few resistors inside the switch housing, but I am assuming that they only operate on the ‘low’ setting that the light has & are bypassed on ‘high’, which is the only setting I use anyway.)
Pictures, including a close-up of the bulb (the IMR16340 is included only for scale):
Printed on the light housing:
Batteries: 4 AA Alkaline
Bulb: 4.8V 0.5A Halogen
Bulb base: P13.5s
Data printed on the two individual bulbs:
HMP20 4.8VO. 0.5A JAPAN
K-15 4.8V HONG KONG
I know that all the data I have supplied is excessive for what should be a simple bulb swap, but figured that it couldn’t hurt to include it.
Thanks much,
K
Bulb base: P13.5s
K-15 4.8V HONG KONG
Thanks much,
K
