Single-Size (26650) L-Ion Battery Charger Stations
b.have
Hi, new here. I'm looking for a L-Ion Battery Charger Station with multiple chambers that doesn't use springs & latches: tight, tension-mounted chambers so when I _firmly snap_ my 26650 L-Ion batteries in place THEY CAN'T SHIFT AROUND. I'm having a devil of a time with a Victagen® "Universal" 2-chamber charger: I just touch this turkey and -- POP! -- there goes my feed.
I want something Solid State and would appreciate your L-Ion Battery Charger Station recommendations. Nothing "Universal" please! All chambers should fit one size ONLY: 26650. Prefer 10-Chambers (or as many as can be found in a quality, solid-state unit) but if necessary I can buy 2. Thank you so much friends. Wow, what a forum.
I'm not aware of any charger that is specifically designed for only a 26x650mm sized cell, no springs or latches, let alone one with 10 bays. Most all chargers are designed for at least a range of battery sizes, some more than others. If you want to elaborate on why you're requesting the specifics for a charger you might get something to suit your needs.
I accidentally nudge the charger and it's enough to kill the feed. Well hmm. I'll go hunting I suppose.
