Enzo Morocioli
Here are a few views of my lighting system.. It's an Streamlight Argo HP with a red Inova X5 attached to the side band.
This here is the X5 on its own.
Next we have the X5 and the Argo HP on "low".
And finally we have X5 and Argo on "high".
I am about 5 feet from the wall..
Both lights are running on lightly burned-in CR123a's.
When i first got the Argo its beam wasn't shaped desirably, so i sanded the bottom of the reflector down with a wide nail file.. I was carefull and checked my progress often, and finally after a little attention i was able to make the beam far more focused. By "sinking" the reflector it better shapes the light, and removes some of the artifacts.. The game you play with it is when screwing on the bezel, as it comes down around the o-ring it also bites the reflector and twists it a bit. Since the reflector is only resting on the tops of the emitter tabs, it tends to turn just enough to add artifacts (and the dreaded doughnut) that aren't there when the bezel is backed off a little.
