At the hardware store. I use PVC pipe. Take the light and batteries and you will find the right size.
If you can't find a pipe that does the trick, I can make you a sleeve out of delrin or aluminum, if you can give me dimensions.
I mad mine out of some high tech Aerospace materials.
Run time....
Math based, not real world test time.
I think the 5761 draws 5500mA at the tail cap....So using DM51's formula...
mAh of the battery / mA draw of the bulb
x60 to get mins.
/80% (usable battery life to prevent over discharge)
IMR26500 = 20mins
IMR18650 = 13mins
