flyingbrass
- Joined
- Aug 25, 2006
- Messages
- 49
I received my L2D a few days ago. While the throw is nice in some situations, flood is better in others. I want a diffuser that slips on or flips up so I can change the beam pattern to suit the circumstances quickly and easily. The Fenix head is only about .85" (21.5 mm) in diameter, which rules out scope covers and the Surefire diffuser.
Does anyone make a diffuser or a cover that can be modified into a diffuser that will fit this light? I haven't found a bottle cap or other convenient item that fits. Even if I do I'd prefer something a bit more classy for long-term use.
I want fairly heavy diffusion, at least as floody Press'n Seal. A white plastic grocery bag stretched tight and held on with a rubber band gives a wide flood pattern. How do the LDF lenses from flashlightlens.com compare?
