small high power NiMH cells
  • Thread starter Thread starter **DONOTDELETE**
  • Start date Start date
D
**DONOTDELETE**
Guest
anyone of you experts out there know of NiMH cells designed to deliver very high currents, which smaller than the 3 Ah sub-C type of cells offered by the established manufacturers for power tools and electro models?
I am looking for something in AA or 2/3A size, is anyone out there aware of such a cell? I know there are NiMH cells available in these sizes but they are not really designed to deliver much more than 1 or, at the most, 2 C without heating up.
I want to build a small but high power diver's light using these cells. Using sub-C cells would make the light too heavy and bulky. Nominal voltage should be 24V (i.e., 20 cells) allowing me to overdrive a 100W halogen bulb to about 150W using a step down switcher, so the maximum current should be around 7 / 8 A.
wus
NiCad gives up current better than NiMH.
Can't help with bulky problem but since it's to be a diving light - you could design the case to be almost buoyant.
Hi,
The highest capacity AA that I have seen is 2000mAh, A is 2700mAh, 4/3A is 4000mAh and 4/3 "fat" A is 4500mAh. The highest capacity 2/3 A that I have seen were only 1000mAh.
What run time are you looking for?
2000ma AA´s ????
From whom ? marketing 2000mas ?
Talked to my local shop guys today when I by accident found some 1900ma in the close-out bin - answer - oh we bought them as they were 1900s (they do carry 1700 Sanyos and 1800 Ansmanns) - tested them to be 1500-1600 and are selling them off cheap - the Sanyos at claimed 1700s are more like 1800-1900ma.
I do like my Sanyo Twicells too though ;-)
Klaus
Ron,
if you like A and 4/3 A´s check out Lemlux posts lately about the nice surplus cells he found at way low prices.
Klaus
