When you get your PM1236, do NOT attempt to wire anything to the 24V bus (actually 28-29 volts on my machine, so the bulb was overdriven and shortlived!). There is barely enough current there for the built-in lamp that comes with the lathe, which is why I decided to wire my 4x LED light directly from 120AC using a transformer/regulator.
And yes, that will be the next shop light to be modified. It gets "way" too hot with the incandescent bulb, so I need to install some LED's in there. I have a couple of ideas, including a triple LED conversion with a shallow reflector but I have had no time to work out the details as it will also need a 120V transformer, regulator, etc...
In the movie Dune, "spice" was the most precious substance in the universe. For me, time is the most precious "thing" - I don't seem to ever have enough time for all of the projects/ideas I want to get done :eek:
