small sealed 12VAC to 12VDC package
tome9999
I want to use some cheap LED strings for a landscape application. My current landscape xfmr puts out 12VAC (actually near 14VAC to be accurate). Does anyone know of a small, 12AC to 12DC converter, sealed so outdoor use wouldn't be an issue?
Besides a full-wave bridge and filter cap, some sort of circuit to regulate LED current is a must. You can even go with a simple resistor if it's only a few low-power LEDs.
Thanks, so is there a pre-packaged package that is ready made to do this?
If not, what regulator (and surrounding circuit) should I build? Can I encase that circuit in epoxy or moldable plastic or something so water won't infiltrate?
Tome
So, if I read that right, I can put 12VAC into it, and can drive a pile of LEDs. However, the output voltage claims 32VDC, won't that fry a string that usually operates at 12VDC?
32VDC is the maximum DC input voltage. As stated on the link:
350mA true constant current output regardless of the number of LEDs connected to the driver
So this would work fine whether you connected it to one LED or several in series.
I haven't been through the AC datasheet but the DC needs about 1-2V overhead.
So for the OP this would mean 14V would drive what 12V is driving now.... assuming the current setup is just LEDs (cheap LED strings... could be a few things), if its a string with a built in driver who know if it will work or not.
I was thinking of buying a cheap xmas light string of led lights and cutting off the AC plug and voltage converter they have (or at least the ones I saw had) and driving the LEDs directly. I admit I don't know the LED specs but did see some 12VDC lights here:
http://www.imaginarycolours.com/Mer...193&Category_Code=12vStrings&Product_Count=13
That I figured might be similar...
Tome
