I've searched thruough a few catalogues but the smallest size I can find is M2. Is there anything that is smaller? Are they very expensive or totally non-exsistence?
I have seen #0-80 taps where I work. My local Ace Hardware has some stainless #0-80 screws, so I might try and use them for some mods. Not sure where you can buy the taps, though.
I have 1/16 taps, thats it 1.58mm . I did not use them yet, just purchased the 3 for $1 in a discount shop here... /ubbthreads/images/graemlins/smile.gif
I can order 000-120 taps locally - which has a nominal diameter of .034 inch - or .86mm, 0000-160 taps are not rare and I can specal order REALLY small taps from http://www.newmantools.com
They list .30 UMN taps (aka - which is .3mm in diameter - yes, 3/10th of a milimeter - pitch is .08mm (or about 384 threads/inch). For those of you who prefer inch - that's .0118 inched - let's call it 12/1000 of an inch. BTW the average human hair is about .2mm - so we are talking taps less than 2x a human hair
BTW for the .3UNM tap requires a .0089-.0095 tap drill
I've found that it's difficult to find anything smaller than a #4-40 tap at the average hardware store.
Other than watch movements and tiny precision instruments, I'm not sure what you'd really need super-tiny screws for... I have a 2-56 tap myself, and have yet to actually use it.
[/ QUOTE ]
Wow! Such a small taps. I wonder what happen if you turn it and it broke while half way thru. /ubbthreads/images/graemlins/grin.gif
PEU - Thanks for the kind offer. I've just came back from a shop specialising in all kinds of taps/dies and have bought a 1.6mm tap. This thing is so small I wonder if it can thread aluminium. I've broke countless number of 1mm and 0.5mm drill bits.
idleprocess - Actually, I don't need ultra small screws. Just searching for smaller than 2mm size. Most hardware shops only stock 3mm and above sizes. Interesting to know that there are something smaller than 1mm!
Good Luck with those tiny taps. My brother was making some parts for me last weekend drilling with 1mm bits. Even though he is an experienced machinist, and has the right equipment, he ended up breaking off some bits. Quite a PITA to make, but he finally was sucessful.
Now I have changed the design to use a larger hole to keep peace in the family. /ubbthreads/images/graemlins/smile.gif Quite a few hours of work to get those parts.
I have done #0 fairly regularly, and sometimes have done 00 and 000 - I've only seen a .3unm. I can scar you with some of the drill bits I have downstairs - the kind that have an enlarged shaft of 2mm
And yeah, they take a soft hand, and GOOD gear to use - you don't hand tap with stuff that small, you MUST guide the tap
