Solar setup LIGHT SENSOR HOW TO???tx
Davekyn
Hi guys,
Forgive me if I am in the wrong place…I am so overwhelmed from endlessly searching the web on issues out of my depth. Currently I have parts to embark on a fully automated solar powered drip system. Not having time during the day (hence the automated watering system) I also need a light source to work at night when I finish my day job (veggie patch takes time to grow food successfully)
Anyways…I’ve decided to split my 2X10Watt solar panels; as the pump I am using only uses 1.9 amp/h and I’ve matched my dripper output to ensure that I only run the pump for no more than 3amps worth to which one of the 10watt panels, can feed that back into the battery on a 5 hour period with no worries here in Australia... (Water pressure tested and all that + running that 3 amp drain on an 18amp/h battery)……………SO I figure I can spare the other 10 Watt panel on a 2W LED spot light for about a 13 hour period for a light sensor to which I have no idea how to hook up. I do know that by judging by my pissy little solar lights that the sensors can cut in up to 13 hours depending on season.
SO…2Watt divided by 12Volt or 2/12 = 167 aprox gives me about 167ma/h……..HEY…I’m fairly tipsy/pissed about now, so please by all means cut in and tell me where I’m going wrong…I’m only just getting to my questions for you guys…
IF I did want to run a light on a sensor switch, allowing for a 13 hour period in the colder months…on a 12V system from a 10 Watt solar panel and 7.2am/h battery…can use one of those little button sized light sensors, or so I have to run it in series/parallel or of some kind of voltage regulator which basically I have no idea of how to incorporate into the scheme of things.
I’ve been searching for a 12V timer switch, much like a tap timer, but something I can program on a 12V circuit + a 7.2amp battery……………that way I could have a higher powered spot light running for 6.5hours instead of 13hours.
Anyways…all is not lost………if worst comes to worst, I’ll just use a manual switch. Just thought It would be good to run a spot light of my 10 Watt panel with the 7.2amp battery to show up my little solar/marker-décor lights J
HELL…What was I asking????...............Oh yea……….what kind of light sensor do I need for my proposed solar and battery set-up and how do solder it in place or where inline???
Thx guys
Dave
Werlcome to CPF, Davekyn 🙂
I think this will probably fit best in Fixed Lighting. I'll move it there now for you.
Too much data and not enough info 🙂
What you have:
1. 12v 7.2Ah battery charged by 10w solar panel
2. 2w LED but what voltage is required? does it work directly off the 12v battery? or are you building a 2w LED spotlight?
Do you want just a dusk/dawn switch or a programmable dusk/dawn timer?
I'm using the following to control my solar light:
http://www.epsolarpv.com/files/EPRC-MFe.pdf
Before I received the EPRC-MF, I used a 300R for simple dusk:dawn operation:
http://www.acetek.co.uk/sitebuildercontent/sitebuilderfiles/CellOptik300R.pdf
Sorry about the rant, bit hazy now 😉
I'm interested in both methods, however was Hoping to be spoon fed the information. As I have absoloutely no idea what you just said.
Dust till Dawn sensor sounds great.
I aslo like the idea of a timer device but have no idea if they exist
I'm simply buying a MR16 LED off Ebay
when I wake up and after checking your links, I may very well end up getting CFL lights yet on a similar system as I here they spread the light better and combined with a cover/hood make a better work ligh. Ofcourse they use more power, but by the look of things, I'll just use a switch and not use it longer than I should.
Back later when my head clears and I check those links.
Thanks for the feed back & thanks for reading............😉
a photo resistor is easy to pick up and you can get one with the specs that you need. That little box has one inside and is marked up a bit. You could put some clear silicone around it to make it less/more sensitive for dusk/dawn setup.
