ernsanada
- Joined
- Apr 29, 2004
- Messages
- 2,962
I just received the Solarforce T4 Full Kit.
Ths kit comes with the Solarforce T4 light that uses a 1 CR123 or 1 RCR123. An optional battery tube that uses 2AA sized batteries.
The Solarforce T4 uses Type III Hard Anodize. The finish color does not match the 2AA Battery Tube. There are some flaws in the finish.
The fit is excellent. Has smooth threads. O-rings were not lubed.
The Lantern fits on the T4.
The lens bezel assembly needs to be taken off. You need to unscrew clockwise, opposite of the usual clockwise to unscrew. When you install the T4 screw counterclockwise into the Lantern Head.
A tripod for the lantern.
This is where tripod screws into the lantern head.
A Headlamp is included. The T4 head screws into it. A L2 Mini head will not screw into this. My headlamp does not work.
Left Solarforce T4. Right, L2 Mini
Battery door has a split ring to keep from loosing the cover.
This is how you adjust the angle of the beam.
OP Reflector produces a smooth beam.
Uses a Cree Q5.
Rear view of the Cree Q5 Module.
Rear view of the lens bezel assembly.
Front view of the battery tube.
Battery has to be installed through the front of the battery tube.
Clip fits in this slot.
Rear forward clickie. It's 2 levels high and medium. The levels look very close. Solarforce should have used a lower low.
Inside view of the rear clickie.
Comes apart in 3 pieces.
I was very surprised on how small the Solarforce T4 is.
The 2AA battery tube makes the T4 long and skinny.
I thought the Solarforce T4 would be very close in size to the Solarforce L2 Mini.
Left, Solarforce T4. Right, Solarforce L2 Mini
___________________________________
These are the lux readings I got. I am using AW's Black Protected RCR123's in both lights fully charged and I used Energizer Rechargeable nimh 2300mAh.
Solarforce T4 Q5 1 RCR123 (High) - 3800 lux @ 1 meter
Solarforce T4 Q5 1 RCR123 (Medium) - 2860 lux @ 1 meter
Solarforce T4 Q5 2AA (High) - 2630 lux @ 1 meter
Solarforce T4 Q5 2AA (Medium) - 890 lux @ 1 meter
Solarforce L2 R2 1S Mini - 5,500 lux @ 1 meter
Solarforce T4 Q5 @ 96"
Solarforce L2 R2 @ 96"
Left, Solarforce T4 Q5. Right, Solarforce L2 R2 @ 96"
Left, Solarforce T4 Q5. Right, Solarforce L2 R2 @ 96" Stepped down exposure
Pros
Smooth beam.
Small
Can use RCR123's.
T4 head can fit on a headlamp.
Cons
Headlamp does not work.
Mis-match of Type III Hard Anodize.
Flaws in the finish.
O-rings not lubed.
Needs a lower low. The levels are too close to each other.
No spare o-rings or rear rubber switch covers.
No holster.
No hole for lanyard.
No instructions.
Uses a Cree Q5.
Pros
Smooth beam.
Small
Can use RCR123's.
Cons
O-rings not lubed.
No holster.
No instructions.
