Sold/Expired SOLD: 3x XM-L 2D mag.
Lumencraft (Matt)
Missouri
Hi all,
Here are the specs on the days featured item.:)
New 2D Mag host
Bororfloat lens
3 deep SMO reflectors
Custom copper heat sink
3x XM-L T6 emitters
D2Flex driver with 5 or 8 level dimming.
Also included with the sale are 3 new li-ion C cells and 2 charging adapters.
Heres a pic of the included charging adapters, they should fit most spring loaded chargers. The battery charger is NOT INCLUDED.
This light produces a great hot spot with very very bright spill.
Low on the wall.
Although this light is a multi emitter it rivals any single emitter light for throw. It easily reaches 100+ yards with usable light.
Now for some outdoor shots.
All outdoor shots taken with camera set to ISO 400 and WB FL.
My truck is parked over 100 yards away.
SST-90 @ 5A tight focus.
3x XM-L Mag on high.
SST-90 wide focus.
3x XM-L on high.
Price is 279$ Shipped!SOLD!
PP is vesture_of_blood(@)hotmail.com
Re: FS: 3x XM-L 2D mag.
You have done another great mod i see. Very nice looking beam. Keep up the great work.
blackbalsam, thanks for stopping in to say so, I'm glad you're enjoying the show. :popcorn:
Outdoor beam shots added.
Nice beam! what's the reflector used?
That's an awesome combo particularly with that massively effective heat sink!!! Plus it's a true thrower!!!
This would make a fantastic light for somebody who wants an easy 'turn key' custom light with big power!!
Good luck with the sale.
James....:thumbsup:
So how's the UI work?
Does it always turn on at High?
Any memory?
Runtime on high roughly?
Does it get superhot?
Thanks!
Ray
Hi Ray,
The UI is like this. Press and hold the switch and it will start on low and ramp up 5 levels ( level 5 is direct drive) at any time release the switch to select that brightness mode. When you are ready to turn it off just quickly press the switch. The next time you press the the light will come on the last mode used.
You can also make a quick leap from low to high by turning the light on and then doing the press hold, or jump to low from high the same way.
This driver has some other tricks it can do too if you are interested but thats the basic stuff. There is a full UI manual here.
http://www.taskled.com/leds/d2flexuni_v2.00.pdf
Run time on high should be around 45 min.
Yes the heat transfers quickly to the head and there is plenty of it. I would keep it to short bursts on full blast. When the head gets too hot to touch its time to turn it down :) On one of the lower setting you could run it for an extended period and still have 1000+ lumen output.
