Re: FS: Brand New Exolion Ti
From the maker:
Specs of this flashlight are:
Full Titanium body
Brass "Can" for better heat transference
UCL™ lens from Flashlightlens.com for 99% light transmission
McGizmo's McR-16 reflector for that perfect beam
Premium TWOH/TXOH emitter
Three stage light (Low, High, Burst), with user adjustable High level
Full O-Ring protection
Green Tritium vial in the tail
Protected RCR2 battery
Dimensions: 50mm x 18.9mm
This light is meant to be a tough key-chain light that hangs together with all your keys for EDC. Even with a Grade 5 (6AL-4V) titanium body, there will eventually be scratches if you put it on the keychain, but it should not affect the appearance of the Exolion as the scratches will blend in with the machined finish of the titanium body. This is unlike an HAIII aluminium flashlight, where each scratch will stand out, appearing in silver, once the scratch is deep enough to penetrate the HAIII layer.
I've always appreciated good throw, and a perfect beam from my flashlights, which is why I will be using McGizmo's McR-16 for the reflector. With the use of UCL lens, this ensures that as much light as possible goes out the front end. In addition, the use of a protected Rechargable RCR2 really makes it a user as you won't have to spend any more money on lithium batteries, and also won't have to worry about over discharging your Li-ion battery.
With the three stage light, this makes it easy for anyone to find a suitable light level. Low level is approximately 30ma to the LED, and Burst is approximately 800ma (subject to change) to the LED. The High level is fully user adjustable anywhere between the two current levels. You will need to twist on/off within 0.8 seconds to go from one light level to the next. Please note that Burst level should only be used intermittantly as the high current to the LED will produce too much heat for such a small flashlight to cope with for extended periods.
The interface is as follows:
1st On - Low
2nd On - High
3rd On - Burst
4th On - Low
5th On - High
6th On - Burst
7th On - User adjustment to High level
