Sold/Expired ***SOLD*** Custom P7 D2DIM 18650
Britelumens
SINGAPORE
Hi guys,
Here is a recent build with a P7 emitter. This build is permanent where the massive custom heat-sink is attach to the host with Arctic Silver epoxy to maximize the heat transfer from the P7 emitter.
-Seoul P7
-D2DIMM Driver
-Metal MOP reflector
-UCL lens
-Run on a single 18650
-Green glow pedestal
-Custom sleeve to accomodate 18650
-Custom heatsink
-Modified tailcap to suit 18650 lithium ion
-Host cut to approxmate 1D size
$210 ship worldwide
For registered mail, kindly please add $2 extra.
First to post " I'll take it, get it" follow by PP to info (at) britelumens. com
The D2DIM feature cut off voltage at 2.7V to protect the lithium ion and utilizes PWM for dimming control. This build is very flexible where the user can set the output to suit his like. From the lowest lumens to the maximum. Here is the post on the build with video.
Some beamshots to share:
With regards,
Jo @ Britelumens
Re: FS: Custom P7 D2DIM 18650
Can this also take a Li-ion D size? or possibly C with spacer?
Hi mcmc,
Yes, it fit a D size Li Ion. Just simply replace the modified tail spring with a mag spring. As for the C cell, it is much shorter so the 1D body would be too long.
With regards,
Jo @ Britelumens
