Sold/Expired sold: D maglite momentary switch with d2flex wired and ready to go 35$
spc
Troutman, NC
D maglite switch with Taskled's newest d2flex driver. Replace your direct drive mag mod with this switch to get dimming control.
The stock mag switch has had the cam cut off, been modified for momentary action, modified to work with flat top cells and has a D2flex dimmer wired in and attached (with silicone wire good to 5 amps). The red icing is high temp silicone to hold the d2flex on as well as give it some protection.
The d2flex is the newest UI from Taskled
***The d2flex is a fequency driver and doesnt regulate current. Your power source must be matched to your emmiter. Heres one example that this will work perfect in= a p7 mag with a single li-ion cell. another would be an sst-50 with a single li-ion. Or even 3c nimh cells with these emitters..... Many combinations
40$ shipped
Sold
Re: FS: D maglite momentary switch with d2flex wired and ready to go
ill take 35$ for it
Re: FS: D maglite momentary switch with d2flex wired and ready to go 35$
PM sent...
your pm box is full Pete! I'll let you know donn, may be sold
Just cleared it buddy, and as per pm - I'll take it, if that's OK with Donn :poke:
I don't stock the parts, but I could build you one- hit me with a PM
