Sold/Expired *SOLD*: Imalent DN35 XHP35 HILED26650 USB Rechargeable Spot Flashlight + OLED Display
ipaulr
Boulder, CO
Imalent DN35 Cree XHP35 HI LED 26650 USB Rechargeable Spot Flashlight with OLED Display
Shelf queen like most of my lights. Never used or carried. Just tested and admired. Like new condition.
Price: $75 shipped within CONUS (Retail was $105)
The original carry case is included (new, never used) but is not shown in the photos below.
  • DN70 is a versatile USB rechargeable LED tactical flashlight with multi-level output and an OLED display. The OLED display can show battery voltage, output, charging, and has a flashing overheat warning, which makes it much easier and more simple to know the status of the flashlight. Utilizing the latest CREE XHP70 LED, its aluminum OP reflector helps the beam to be distributed more evenly. There are four output levels, with the tactical-switch button making it easy to operate. With a maximum output of up to 3800 lumens, the IMALENT DN70 should satisfy any customer for any occasion.
  • As a pocket size flashlight, supported by a single cell of IMALENT 26650 4500mAh Li-ion rechargeable battery, its advanced temperature control module, low-voltage warning, and low-power protection make the DN70 the perfect flashlight for working, exploring, searching, rescue and as an EDC.
Description:
  • The OLED display can show various parameters.With high drain 4500mAh 26650 Li-li-on rechargeable battery
  • Product size: 113(length)*38 (head diameter) *32 (diameter) mm
  • Weight:115g
  • High efficiency constant power circuit will maintain constant brightness
  • Anti-reverse battery protection
  • Built-in thermal control module will automatically adjust the brightness output
  • According to the working state and outer temperature
  • Combination of toughened ultra-clear mineral and anti-reflective coating glass
  • Aluminum OP reflector
  • Aerospace-grade aluminum alloy body, wear-resistant Type III hard-anodized surface
  • IPX-8 standard waterproof (2 meters submersible)
  • 1.5m impact resistant
  • Tail stand function
How to Use?
  • 1. Take out the battery protection pcs
  • 2. Screw it as tightly as you can, as the flashlight need high current, so if not tight enough, it won't be able to pass 15A current.
  • 3. If it doesn't work, use cloth to clean the contact parts like battery pack and the copper rings inside the flashlight head.
  • 4. When press the button, make sure it is just click but not hold it as hold it for 1 second will be turn it off, so the flashlight will not turn on when you hold it.
  • 5. Do charge the batteries before you use
Accessories:
  • 4500mAh 26650 Rechargeable li-ion battery *1
  • Holster *1
  • USB charging line*1
  • O-rings *2
  • User manual *1
  • Carry case *1
Imalent DN35 01.jpgImalent DN35 02.jpgImalent DN35 03.jpgImalent DN35 04.jpg
