Sold/Expired SOLD !! P7 DSXPJ Upgraded Novatac 120P Tons of Pictures !!
Sabrewolf
Ambler P.A.
Here is a nice little gem that i just built a couple of days
ago. Its a Novatac 120P with a P7 Shovelled in it.
The Output is quite insane on this thing :duck:
When you run it on 100%, The thermal detection circuit
that is builtin will throttle the light down a couple of
notches after about 30sec or so. So if you want a super
powerful Edc in a P7 form, You have to make sacrifices :ironic:
If you want to run this light on a slightly lower-than-
high output to save it from backing down a bit, Just
check out the manual on how to do so.
All threads are Clear Silicone Greased, and the Thermal
surfaces are covered in Black Carbon Silicone for added
thermal transfer.
The options that are programmed in it now are:
Level 1=60% which is a Single Click from Off
Level 2=100% which is a Double Click from On
Level 3=~2% which is a Triple Click from ON
Level 4=Puke Strobe which is a Clik-Press from ON,
or Off. If you hold it down, then it will latch On from the
after you turn on the light with a single click. If you run
the strobe from off, then it will be a momentary.
I have also set the Momentary option too, IE, from Off,
you just hold down the button for a Momentary output.
To Latch it on, just Click it. The light is setup for
Rechargable Li-Ion 123 3.7v batts. That means it will
detect the battery capacity, and shut it down safely at
the 2.5v mark to save Non-Protected 123's. If you want
to run the Primaries, just follow the instructions for that.
Since i Edc'ed it for a little while, there are pretty small
scratches on the body, and some small blemishes in the
anodizing :mecry: They aren't real noticable to a wandering
passerby :thinking: The Front bezel has been Heat treated by
yours truly. The lens is the same factory coated one.
The Reflector has been orange-peeled even more to cut
down on the dougnut a bit. I couldn't get a clear shot of
the reflector to show the tiny scratches i accidentally
made when boring out the back. There must have been
a small piece of aluminum that swirled around the inside
when i wasn't paying attention :ohgeez:But i did do the
clear-coating After this happened. So if you are very
very picky, please take this into consideration.
As allways, I let you all know this stuff BEFORE i sell
the light to you, as there are NO Suprises :grin2:
Onto the Pictures !!
And Now for the Beamshots!!
Indoors :candle:
Backyard :candle:
Okay, Now the fun part :broke:
I am asking 220.00 Shipped Conus with 175.00ins.
Paypal CC please Add 4%
International Shipping and Insurance is Extra.
If you want to make a Trade, Please shoot me a PM..
Thanks All!
Super:poof:
Robert M.
Re: P7 DSXPJ Upgraded Novatac 120P Tons of Pictures !!
Still available and its waiting for a hand to keep it warm in the winter :candle:
I though this would infact warm the hand........................?
:naughty:
:naughty:
Yeah, Just a little bit though :mecry: It has thermal management to keep
the Led at a lower temp. So, Not too much of the heat from the P7 gets
to your hand before the T.M. kicks in.. It works quite well too!
You wanna buy it?? :poke::poke::poke::grin2:
Just a gentle bump my friend.....:twothumbs
Either way my PP is crapping out on me...
