Northern Lights
SOLD-RECHARGEABLE 2C P7, Modes, Electronic GID switch Possibly the first mods with the new D2FLEX mode modulation.
D BIN! BRIGHTEST BIN AND MATCHED TO THE FORWARD VOLTAGE FOR MAXIMUM OUTPUT!! This is often over looked in direct drives, but Forward Voltage must be compatible to Battery Voltage in order to obtain maximum performance. This light is as bright, same spill size and throw as my max'ed out E-molie 26700, 5761 3C-cell size with an aspheric lens. An LED at nearly 900 LUMENS out the front! My 5761 link. It is the brightest P7 I have built, taking advantage of the Vforward 3.75 volts and the nominal 3.7 Vbattery of the emoli. Brighter by a little than than my other builds.
Check the features available in these lights. Comparable pricing, more features in one package than the others sporting P7.
This light contains the same features; I encourage you to look at the thread through this LINK:
1.5 D P7, Modes, Charging Jack, Electronic GID & more
WHAT IS BETTER OR UNIQUE FROM OTHER P7 BUILDS??
Look below; in brief longer run times with premium batteries, best reflector, it is rechargeable in minutes and with improved features
1 D BIN 900 lumens at 2.8 amps at the maximum FORWARD VOLTAGE OF 3.75 VOLTS, MOST D BINS AS THIS ONE ARE FORWARD VOLTAGE BIN J and are NEEDING 3.75 VOLTS TO REALIZE MAXIMUM OUT PUT.
2 No Driver limits the amps; this light usually is overdriven and brighter than the 2.8 amp specification.
3 Sputtered reflectors and OEM smooth reflectors do not put out the light like this premium reflector,
4 You get three all reflectors if you request it, but why bother, the OEM and sputtered are very inferior to this metal LOP.
5 Single E-moli, 26700 from Milwaukee battery from packs are 3000 mAh of safe lithium chemistry (no explosions or fire) and run over an hour; more than 18650s which are a maximum of 2400 mAh no matter what they say, Chinese Batteries are usually over rated. These cells can recharge fully at 10 amps, easily at 5 amps and can be ready in 10-15 minutes not hours, depends on your charger.
6 Rechargeable Charging Jack, charge the light with a cord, who else has this?
7 Coated lens (window) transmits more light
8 Glow in Dark (GID) switch cover that is powered by an always-on 5mm LED in the switch on low power consumption! Does not drag the cells down.
9 Switch stroke is shortened for smooth operation and feel.
10 Pinned heat sink prevents twisting of wires when head is turned
11 H22A sync is solid and handles the long runs
12 Tail cap resistance is nominal because of braid jumper modification
13 Special care has been taken to insulate and/or strengthen solder connections to board and Jack.
14 D2DIM is replaced with NEW D2FLEX allows for tactical straight OFF/ON programming. It is not necessary to cycle through modes to operate the light features. The light will be shipped with the default program and Taskled.com instruction booklet. D2FLEX link
15 Care has been taken to reinforce ground connection, solder joints and to insulate exposed connections.
16 NEW D2FLEX more modes, less resistance brighter output, 3 User Interfaces! Flashlight, Fixed and Bike. TWO strobe modes available but not necessary. D2DIM is obsolete! Any other P7s have the new system?
***THE NEAT STUFF!**
~Automatic thermal protection is programable in the NEW D2FLEX, automatically reduces output until cooled off to your selected values.
User Inerface Portable and User Inerface Fixed is for flashlights. I like UIF best. I set the light so that a press and release starts dim and can be brightened in 7 steps or a press and hold starts in night light then jumps to full bright. Click starts in bright. Subsequent press either brightens or dims in 7 steps! A click and it is off, best for tactical. Two ways to immediately get full bright and yet can start in dimmest mode to save night vision!
UIF click starts either last brightness value or at FORCE set level, a press starts low and brightens in 5 steps.
Strobe in Bike mode~
WHAT IT CONTAINS:
2C MagLite , pewter color
Seoul Semi Conductor P7 D bin with higher voltage J bin LED from KD, DSXOJ
Binning and labeling http://seoulsemiconductor.cn/en/product/prd/acriche.asp
H22A new style heat sink setting on thermal grease
Heat sink is pinned to prevent spinning when assembled and allows take down.
D2FLEX PWM (taskled.com) mode control with three User Interfaces programmable Modes
Monetary only short stroke modified switch
GID switch cover that is powered by an always on 5mm LED in the switch on low power consumption!
Charging Jack, any lithium E-moli or RC charger that handles E-moli can be jumped to charge this light
Bored for the Milwaukee E-moli 26700 safe lithium 3000 mAh battery.- WAY MORE RUN TIME THAN 18650!
Tail cap with copper braid jumpers to reduce resistance
Three reflectors, if you ask for the others!
KD 52 mm LOP, aluminum
KD coated clear lens
D2FLEX links: http://www.taskled.com/techd2flex.html and Dichotomous Chart
sOLd $ USD
Quick summary:
More than just off and on for same price class
Compact size, proven commercial (not home made) reflectors
P7 brightest bin, one of the brightest single LED available!
Coated optics for maximum output
Rechargeable light, "in the light" recharging
Electronic Glow in the Dark locator in the switch.
User programable Modes, 3 User Interface programs D2FLEXlink
Safe lithium power, long steady output runtime superior to 18650s
Excellent construction features mechanical and electronic
Quick summary:
Buyer pays shipping, shipped US Postal Service, http://www.USPS.com ,and mailing insurance. Shipping is done on receipt of payment, PayPal or certified check or money order. I will honor the first "I'll take it" without conditions posted in the thread. I check CPF in the night, Mountain Standard Time, UTC/GMT -7 hours. Private Message the specific details please.
This is a custom modified light; Consider since it was not made for commercial sale then it is made with used parts. All the components are modified and are not in the original condition and configuration of the manufacturer. While these batteries are considered a "safe" the buyer assumes all risks and responsibility to use this light safely and appropriately. This is a private sale and there is no warranty or guarantee. By making this purchase the buyer certifies they are at least 18 years of age and assume all risks and responsibility to use this light and parts safely and appropriately and accepts the light and parts in an "as is" condition.
