Like New SPY005 with titanium knob and head. Also one of only 3 with Cree. Black finish with the Crow logo on the bottom. Number 124.
Here is part of Data's original sales info:
"I am very excited to bring this two cell LED light to CPF! This little every-day-carry light has 6 levels of buck boost regulated power controlled by a silver knob on the “front” of the light. It loads two CR-123 lithium cells, a top bin Lux3, the finest orange peel reflector and a super trick battery cap.
The SPY005’s most unique feature, its side-by-side arrangement of two batteries, is made possible by the advanced CNC machined body and battery cap. The machining required to manufacture this light is extensive and it sets the SPY apart from any other light ever offered for sale. With its two primary cells, the SPY has extended run times while providing a considerable level of light.
The side-by-side arrangement of batteries also provides an optimum location for the brightness level control knob. When the user rotates the knob, it clicks from the off position and continues clicking through 6 discrete regulated output levels. The first level is a very low nightlight setting, perfect for a dark room or tent. The middle 4 levels will be the ones used most, and the highest level, intended for intermittent use only, drives the LED at 1000mA providing a very bright combination of fill and throw. Holding the light in the palm of your hand with the knob up or knob down seems natural either way. It soon becomes quite addicting to play with."
Specifications:
· Batteries: two CR123 primary lithium, run in series
· LED; Luxeon 3 Under 4Vf, premium bins only
· Six regulated light levels, high efficiency buck/boost converter by Wayne Yamaguchi
· Current levels: 1000*, 700, 400, 100, 20, 6mA, * intermittent use only
· Rotary switch is mil-spec’ed and rated for a minimum of 10,000 full cycles
· Reflector is McR-18
· Body made of 6061-T6 aluminum HA III natural finish or black.
· Head made of 2024 aluminum 0.88” in diameter and is chrome plated on outside surface
· Water resistant with o-ring seals at the head, cap and knob
· Overall dimensions: 3.03” x 1.52” x 0.88”
SOLD, Paypal/CONUS (not echeck). Includes PP fees, shipping and insurance. If you'd like to own one of these fantastic lights with a titanium head and knob, without paying close to $1000, this is the light for you.
Batteries included.
Specifications:
Batteries included.
