dmdrewitt
Sold :- Titanium Gatlight V3
Details also at :-
Gatlight Website
Flashlight Forums
CPF Lumencraft Sub Forum
Excellent condition. Carried only a handful of times. There are slight marks on the front of optic that can only be seen when held up to a bright light.
(Current Gatlight price $395 + Shipping.)
Sold $350 $347 $342 $337 $329 including worldwide shipping by Royal Mail Airsure which has tracking, PayPal only, no fees.
Light source: Premium bin LED selected for brightness and color tint (pure white) rated at 240+ Lumen by manufacturer. However the real Lumen output is lower - our guess is around 130-150 Lumen.
Optics: Circular Narrow Beam Optic with half angle divergence of only 6 degrees.
Brightness Regulation: Proprietary regulation circuitry maintains constant light level as battery voltage drops.
Materials: The metal parts of this light are made of 6AL-4V (grade 5) Titanium – an aerospace alloy many times stronger than the more commonly used grade 2 titanium found in jewelry. The thread of the back knob is sintered bronze, a self lubricating alloy to prevent galling (thread locking) often found with titanium threads. The battery tube is made of light weight carbon fiber composites with a ground & varnished 4x4 twill weave cosmetic layer.
Gold plated contacts for minimum electrical resistance and corrosion protection.
Machining: High precision components with <0.0005’’ (0.01mm) tolerance. Machining surface finish of less than 4 Ra
Number of parts: Each GatLight consists of over 80 parts. 42 parts are custom machined metal parts. The 24 screws are custom made on high end Swiss screw machines, since stock screws did not meat the quality demands for this light.
Serial Numbers: Each GatLight contains a unique laser marked serial number showcasing the limited production of this product.
Operating Life LED: 100,000h (11 years)
Dimensions: 3.5’’ x 1.125’’
Battery: 3V CR123 Primary Lithium. To replace battery simply unscrew the knob in the back.
User Interface: Push button switch with momentary functionality and a rotary knob to adjust brightness.
Low Battery Indication: When set to full brightness flashlight maintains constant brightness level. When full brightness can’t be maintained anymore (battery low) brightness level drops. After a while the light will begin to strobe – indicating that battery needs to be replaced. After a while the strobe stops and the light can still be used at a very low brightness level for about an hour – until the 123 battery is fully depleted.
Multi Brightness Levels: Unlimited regulated brightness levels are available by turning the knob in the back allowing either maximum brightness or maximum runtime or any setting in between.
Water Sealing: The light is designed and built to be fully submersible – however individual units have not been tested by submersion. As a result the official rating is “water resistant”.
Assembly: Each GatLight is carefully hand assembled by skilled aerospace technicians from over 80 parts.
Heat sinking: Design provides maximized thermal efficiency by maximizing exposed surface area. Solid Copper core LED board maximizes thermal dissipation. LED is mounted to circuit board using high performance thermal epoxy commonly used in spaceflight applications.
Accessories: Each GatLight comes with an attractive solid wood display box with a bronzed Lumencraft logo.
Please feel free to ask questions. The first "I'll take it" in the thread secures the Gatlight.
Details also at :-
Gatlight Website
Flashlight Forums
