PaperKnife
- Joined
- Aug 3, 2020
- Messages
- 49
ZebraLight SC600Fc MK IV Plus 18650 (4000K)
Never really using this light anymore. It's essentially brand new.
Price: $60
Price is Total through PayPal G+S (that includes shipping).
I'll be shipping out USPS Priority CONUS.
I ship out same day.
Edit: Does come with Metal Clip and 2 spare o-rings.
Let me know if you have any questions.
Information Below is Copy/Paste from ZebraLight's Site for Reference:
Price: $60
- Cree XHP50 Neutral White LED
- Nominal CCT: 4000K
- Typical CRI: 93-95
- Tint deviation: 3-step
- User Selectable Levels: 3 main levels (High, Medium and Low). Each main level can be programmed to one of its two sub-levels. The second sub-level of the each main levels can be further programmed to different brightness levels.
- Light Output (runtimes)
- High: H1 1816 Lm (PID, ) or H2 1035 Lm (PID, )/557 Lm (PID, )/283 Lm ()
- Medium: M1 135 Lm () or M2 61 Lm ()/26 Lm ()/10.5 Lm ()
- Low: L1 4.0 Lm () or L2 1.4 Lm ()/0.5 Lm ()/0.15 Lm ()
- Beacon Strobe Mode: 0.2Hz Beacon at Low / 0.2Hz Beacon at H1 / 4Hz Strobe at H1 / 19Hz Strobe at H1
- Operating Voltage Range: 2.7V - 6.0V
- Battery: One 18650 size (i.e. unprotected, 65.0-65.2 mm long) 3.6-4.35V li-ion rechargeable. Batteries are not included in the package.
- Parasitic Drain: Negligible (much less than the self discharging of a battery)
- Beam Type
- Floody beam from frosted lens, with a 90 degree beam spread
- Dimensions
- Head Diameter: 1.2 inch (30 mm)
- Body Diameter: 0.98 inch (25 mm)
- Length: 3.8 inch (96 mm)
- Weight
- 2.26 oz (64 gram) without battery
- Features
- PID thermal regulated outputs (three highest output levels)
- Builtin battery protections with continuously monitored temperature, current, and voltage, plus a (2.7V) low voltage cutoff
- Battery capacity indicator (LED flashes 1-4 times, 4 short clicks to start)
- Automatic stepping down from High to Medium, and from Medium to Low when battery capacity is low
- Durable electronic soft-touch switch
- Smart user interface provides fast and easy access to all brightness levels and beacon-strobes.
- Precision machined unibody casing from premium grade aluminum bar stocks
- Proprietary heat sinking design bonds the LED board directly to the unibody aluminum casing
- Durable natural hard anodized finish (Type III Class I)
- Sealed and potted LED driver circuitry
- Tempered optical grade glass
- Orange peel textured reflector
- Battery reverse polarity protection
- Pocket clip
- Lanyard ring
- Waterproof to IPX8 (2 meters, 30 minutes)
