solution to LS twisty problem
Status
Not open for further replies.
Led-Ed
Vermont
I was messing around with aluminum foil in the bottom of my LS "twistys" and was not that satisfied with the results.
So -I used a knife on the bottom of the Surefire 123 cells I use , and if you take the bottom blue pastic collar off the battery the twisty works just fine every time.
Your milage may vary but this works great with Surefire cells.
Great idea - thanks!
My Twisty is working fine as is, but it sure looks like it is close to bottoming out. If it ever does, I'm sure triming the thick (12-15mil?) plastic covering will do the trick.
Status
