MatajumotorS
Recently took some capacity tests of my 18650 cells. I tested 2x AW flat-top cells, 2x AW button-top cells (2200mAh), 2x TrustFire cells (2500mAh), and one cell harvested from old laptop PC (unknown capacity).
All cells were charded from same charger to 4,21V (other DMM showed 4,19V). 4 AW cells i charged in paralel to enshure the same state of charge.
As the load, i used "semi" constant current load based on LM350 in current source mode, set to 1,2A. "Semi" constant - because @ 3V it drops to 0,9A. I am working on constant current load adjustable to 10-15A and min voltage as low as 1,5V.
And here is the graphs: larger picture HERE
All AW cells were used in one light, isn't it strange? - so big diference? See the cell AW3 and AW4, they are almoust identical, only the internal resistance of one is lower.
