digitaldave
- Joined
- Jun 18, 2008
- Messages
- 164
I've been reading around about some of the Surefire range, and all I've managed to do is get myself confused
. So, I have a couple of questions that I hope you guys can answer...
1) I've read that the Surefire range isn't recommended to be used with rechargeable 123 batteries, and one review said that you get a flashing light if you use them. Is this because recharegables are usually about 3.7v? If so, would the problems be solved by using a 3v version such as these ones?
2) Is there a good, reliable and reasonably priced dealer in the UK? Or would I order direct from Surefire's web site?
3) The output levels quoted on Surefire's web site seem to be lower than equivalent lights from other manufacturers. Is this just a case of different people using different measurement techniques (or heaven forbid, reporting inaccurate values!)? If so, how on earth is one supposed to evaluate the output levels in order to compare against lights from other manufacturers? Apart from reading reviews on here of course
4) Finally, and probably contriversially, what's all the fuss about? Please don't start a flame war, I'm just interested from a noobs point of view as to why so many people like and recommend them
Thanks,
Dave.
Thanks,
Dave.
