flownosaj
Just back from the garage. I've been playing around with my KL1 and everything was going great untill it came time to remove the new emitter from the board and perform the "transplant"
To set the scene, KL1 is apart on the bench with the old emitter removed and sitting next to it. The new led is still attached to the board and I've used a dental pick to remove the leads once the solder has melted. So far I'm feeling pretty good about how things are going. I've heard that some people take a dremel and cutting wheel to the back of the board but I figure it must make a lot of heat and there must be an easier way.
I take a pair of forceps and figure that the easiest way would be to just twist. One hand tight around the board, the other tight around the forceps and *twist* Something sliped-the lens went flying and the board went to the ground.
I'm now the proud owner of a severley scratched lens and a bashed phosphor. Oh, it would have been fine if it was something simple like a cheap one, but guess what-- it was an R2H!
For next time I'm silly enough to try this, does anybody have an easier way remove the emitter from the board?
/ubbthreads/images/graemlins/help.gif
I'm gonna go out to the garage and sulk for a while... /ubbthreads/images/graemlins/frown.gif
-Jason
-Jason
