MWClint
Picked up a smooth dereelight reflector a while back with the intention of using it in a mag. was bored today, so i figured i'd see what i could come up with.
cut down a 2C mag and used the section with the threaded tail. cut it down to size to use with an aw 18650.
the head is lightly silicone glued for now. i might send it out for rethreading. I also plan on mounting a switch in the tail cap. for now it's ok as a twisty.
led is just a cree q5 wc i had lying around and am DD'ing it for now. I have some 800mah drivers, but DD is starting me at 1.3amps, so i'm leaving that
until the 1.2amp driver arrives.
i cut the heatsink from some old brass stock and press fit it down into the battery tube. ran the wires and it's good to go.
here's some quick pics.
