Sold/Expired SPF: Another Stubby Mag
saltytri
SOLD: Another Stubby Mag
$175 conus
This time, it's a C Mag. This along the same lines as the last one ( http://www.candlepowerforums.com/vb/showthread.php?t=277586 ), which was made to try out a recessed switch in the tail cap.
The tail cap is pretty much like the last one, but smaller. It starts out getting internally threaded and bored at the end.
A trim ring is threaded to the bottom of the tail cap....
....followed by the rubber boot and a Fenix switch.
A retaining ring holds everything in place.
The body is cut off at both ends, leaving only the knurled section. Both ends are re-threaded.
The heat sink is threaded to keep it secure in the body. The driver, a three-level ShiningBeam #1131, is held in place by a brass retaining ring.
The business end is an XP-G R4 (2B tint) from ShiningBeam. The supplied wires from the driver are replaced with 24AWG Teflon.
A plastic tube holds an 18650. It fits both the AW 2200mAH and 2600mAH cells.
Here's the catch. Along the way, I noticed rub marks on the tail cap knurling. I don't know whether I did this or it came that way but, even though the marks aren't obvious, I consider them to be a defect and the light is priced accordingly.
The reflector is an MOP from DX. It gives a narrow and very bright hot spot with a large ring of spill that has a well-defined edge.
The lens is glass.
The current at the tail cap is:
1.38A on high
.40A on medium
.06A on low
This wasn't intended to be the brightest light on CPF but, rather, a reasonably strong light with good run time. According to the Cree data sheet, the XP-G should be putting out about 400 lumens on the high setting. This ought to be plenty to keep anyone from getting lost in the dark!
Re: Another Stubby Mag
Another nice one, well done :twothumbs
WOW! Status upgrade from Flashaholic to MMM - Master Mag Modder!
I'm keeping my eye on you!
Beautiful Build!
Another beauty. And in my price range! ;) Do you have any beamshots of this one?
EDIT: Also, what's the tint like on the XPG 2B?
I'll get beam shots up when it gets dark - I just finished this today.
As for the color, that's pretty subjective but I'd call it "pretty darned white." :laughing: Certainly not warm but not green either.
There's actually a little more to the story. The first emitter that I glued on was an XP-G R4 that I got from Cutter. It was so green that I put the heat sink on the lathe and just faced that lousy thing right off. That left a shiny new surface for the current R4. I've got a couple more of the Cutter R4s if anyone wants some really green light. :thumbsdow
It's pretty dark here on the East Coast right now. :grin2: I checked out the binning info on Cree's sight. Looks like the 2B should be about 5700K. Definitely interested in this one. :thumbsup:
You still awake? Here are some beam shots. This thing actually impresses the heck out of me as a thrower, especially for the relatively low power consumption.
I can't resist any longer. :poof: I'll take it! :thumbsup: Please PM me paypal info.
Those are some crazy beamshots!~ It doesn't appear to have any spill and a beautiful hotspot!
Is that the WF-500 SSC P7 reflector?
Wow, what a beautiful Maglite forward clicky!
If you where to sell D sized clicky tailcaps separately, I would buy them
Congrats to a great Flashlight.
And my tribute to a great Modder.Awesome work.:wave:
Hope you do more of these.Maybe a stubby pewter D Mag with a SST-50 or 90.:D
Thanks, ninemm! PM sent.
The reflector is DX sku# 18072. There is a certain amount of spill but it seems like most of the light gets bunched up in a little ball and pushed well down the block.
Thanks for the comments, folks.
:paypal: Thanks for being patient saltytri! Looking forward to trying out my first Mag!!
Great light at a great price. The amount of work you put into screw cutting is unreal! Most people would avoid all that extra work, and somehow you seem to enjoy it.
I was wondering, did you have to space the reflector off the LED solder points to prevent it shorting?
Hi, Essex - good to hear from you again.
Yes, you are quite right about the solder contacts. For optimum focus, this reflector needs to get close to the emitter board. In fact, the best focus seemed to come just as the flat rear surface of the reflector was about to cause a short. To prevent a potential problem if the owner turns the head on its threads, which is certain to happen, I put a layer of Teflon tape on the rear surface of the reflector. This isn't the micro-thin Teflon tape that is used to seal plumbing threads but a much thicker adhesive-backed tape. The advantage of using Teflon here is two-fold. First, it's non-conductive. Second, it's slick and as it contacts the solder pads and wires, it slides rather than tearing.
Nice work Saltytri! I been eyeing your creations waiting for the one that calls my name.
How are you centering the led?
Thanks!
AlexGT
Thanks!
AlexGT
Thanks, AlexGT!
Here's photo of a heat sink that I'm working on. I make a plastic tube that is bored to accommodate the emitter and put the tube in a chuck in the lathe tail stock. This then holds the emitter in place against the heat sink while the glue dries.
