ShineOnYouCrazyDiamond
For sale is a Volere AA in Mint condition. I've installed a blue trit in the tail. Also - I have swapped out the driver with a L-mini II driver. This driver is a buck/boost driver which does make the light a 14500 only light, but it's really nice and clean mod. I had to dremel both layers of the driver until it fit just right (as you can see in the pics below).
This light is really sweet stock, but this mod fixes two of the most common issues with the stock driver. The 3 brightness levels are much more distinctive as a Low-Med-Hi (3 drive levels - 1A, 350mA, 80mA). And the heat on Hi. This driver runs much more efficiently on high and the light can easily be run for 5-10 minutes plus when hand held.
More details here: http://www.candlepowerforums.com/vb/...d.php?t=293509
Included in the sale is:
Volere AA light with L-mini II driver installed.
2 x 14500 AW protected Li-Ion cells.
Stock Volere driver.
Note: The stock driver will be included in the sale in case you ever want to put it back in. If you prefer I can swap back in the stock driver (if I do the L-mini II driver will not be included in the sale, nor will the 14500 cells - price will remain the same for the purchase). This will cause shipping to take an additional few days for the driver swap work.
I purchased this light for $225 and that is what I want to make back NET to me. SPF
PP purchase option only. Add 3% for fees.
First Class conus shipping included.
