Are customs opening them in the US? Or just being slow to process them?
I fill in all the paperwork honestly, but after that it's in the hands of US customs.
I have no idea, tracking just says, "Inbound Into Customs"
From now on I'll be warning Americans about their own customs delays. It's not even the same delay for everyone. Looking at the tracking data, some of you had a two-day delay, while others are still waiting after two weeks. I sent some on Jan 4 which arrived by Jan 10, while others sent on Dec 20 are still waiting! I'm upset for all you guys, but it is out of my control.
I'm surprised that the 17670s don't work. Is it because they also have flat tops and don't make contact? Or is there something else going on?
I'm also surprised that you can't get a magnet in the gap. How thick and wide are your magnets? I can send you some that will fit.
I've been using Xtar's Panasonic cells and they work well for me.
How are you planning to use the soldering iron? I'm nervous about putting solder blobs on your cells. I also advise against soldering to the brass contact in the battery case. The plastic will soften.
If you really want to use flat-tops without magnets, then my advice is to carefully drill two holes through the middle of both +ve contacts, and screw in two screws. You can drill the holes easily from the plastic underside on the holder. Then put the screws in from the inside so that their heads make a button to contact your flat-tops. If you choose the drill size well, then the screws will bite into the brass and plastic nicely. Ideally you'd tap the hole so that the screw goes in nicely. Washers can be added to raise the height. I can send you brass screws that should work, but you'll be much quicker getting them locally for under $1.
The circuit does have reverse polarity protection. My bigger concern stems from the fact that the two cells are wired in parallel. So if someone reverses one cell, then they will form a closed circuit. This is not good. If the cells are protected then it's probably not a problem. However, sooner or later some fool will buy unprotected cells and I don't want to be responsible for blowing a hole in the back of their head.
I'm sorry you've had a rotten experience with the shipping and the product. I'll happily give you a refund for the product if you send it back to me. Sadly you will have lost the shipping expense. Or perhaps you can sell it on to someone locally. I'll gladly set you up with the Americans on my order list.
I'm worried about the fact that the 17670s give a flash and then nothing.
Can I assume that they are normal lithium-based cells with a maximum voltage of 4.2V?
The brief flash suggests to me that they are tripping their protection circuits. This should not be happening unless they have a very low trip current (unlikely).
If you have a multimeter, check the voltage of your cell, then put it in the headlamp and check the voltage again (you can use the empty slot to check the voltage).
If it starts outside the 3.0 - 4.2V range, then we want to know why.
If it drops to 0V when in the headlamp, then we want to know why.
On a different note:
Do the curved brackets fit the helmet well enough?
The 17670 is an AW 1600mAH one and measures 4.159V by itself, 4.158V when in the Headlamp.
The bottom two LED's light up briefly when one or two 17670's are inserted and then nothing happens when I press the button and hold.
Am I not turning it on correctly? I tried several combinations of long presses and shorter presses.
